Einleitung
RAM is an essential Computing Module. Having faulty RAM will cause your computer to not work, and increasing the amount of RAM can make your computer work faster. The HP Pavilion dv7-3065dx can utilize a maximum of 8 GB of total RAM, and comes with a standard 4GB.
Was du brauchst
Place the laptop upside down on a flat surface so that the bottom is facing up.
Carefully pull out the battery while holding the latch to the open position with your finger.
Remove the four circled screws using a #1 philips head screwdriver
Pry off cover and place to the side.
To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
3 weitere Personen haben diese Anleitung absolviert.
