Zum Hauptinhalt wechseln
HP Pavilion dv7-6163us Touchpad Replacement
Was du brauchst
  1. HP Pavilion dv7-6163us  Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over so that the bottom is facing up.
  2. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Place your finger on the battery release latch and slide it to the right to release the battery.
    • The battery will pop up after sliding the latch.
  3. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Firmly grasp the battery and remove it from the device.
  4. HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: Schritt 4, Bild 1 von 2 HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: Schritt 4, Bild 2 von 2
    • Remove service door by prying the plastic opening tool or the spudger under the door.
    • Lift door and set aside.
  5. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 5, Bild 1 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 5, Bild 2 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 5, Bild 3 von 3
    • Remove the single screw securing the optical drive in place.
    • Detach the optical drive by sliding your fingers between the drive and the body of the laptop.
    • Pull out the optical drive.
  6. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Remove all visible screws:
    • Remove the four 10 mm screws (one at each corner).
    • Remove the remaining twenty-five 3 mm screws.
  7. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 7, Bild 1 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 7, Bild 2 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Turn the laptop right side up and open the screen.
    • Use the plastic opening tool to loosen and remove the keyboard. Begin in the middle top of the keyboard and work around the edges.
    • The keyboard will snap out, but do not remove it completely. It is still attached to the device by a ribbon cable.
  8. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 8, Bild 1 von 2 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 8, Bild 2 von 2
    • Flip up the keyboard to access the ribbon cable underneath.
    • Disconnect the keyboard ribbon cable from the motherboard.
    • Remove the keyboard.
  9. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 9, Bild 1 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 9, Bild 2 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Release the faceplate with your fingers or a spudger. Begin at the top left corner and work your way around to snap the faceplate away from the body of the laptop.
    • Turn over the face plate to access the underside of the touchpad.
  10. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 10, Bild 1 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 10, Bild 2 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 10, Bild 3 von 3
    • Disconnect three ribbon cables.
    • Remove the eight screws securing the touchpad plate.
    • Remove the touchpad plate.
  11. HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 11, Bild 1 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 11, Bild 2 von 3 HP Pavilion dv7-6163us  Touchpad Replacement: Schritt 11, Bild 3 von 3
    • Pop out the touchpad using a plastic opening tool. The edges should snap out of place.
    • Remove the touchpad.
Abschluss
Kaylee Cort
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 976
