Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you the steps to remove and replace the battery in your HP Pavilion dv7-6163us laptop. Replacing the battery might be needed if you have an old battery that may not hold a charge well.
  1. Turn the device over so that the bottom is facing up.
    • Turn the device over so that the bottom is facing up.
  2. Place your finger on the battery release latch and slide it to the right to release the battery.
    • Place your finger on the battery release latch and slide it to the right to release the battery.
    • The battery will pop up after sliding the latch.
  3. Firmly grasp the battery and remove it from the device.
    • Firmly grasp the battery and remove it from the device.
Abschluss
Chanah Carter
97 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 178
