Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Having trouble with your data storage? You may need to replace your hard drive. If your personal computer gets a virus, you may need to change the hard drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.) After that is done, carefully pull off the back piece. It should look similar to the second photo.
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  3. Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  4. Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop. Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Zach Lunghi
127 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 11
Insgesamt: 181
