Zum Hauptinhalt wechseln
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: Schritt 1, Bild 1 von 2 HP Pavilion dv7-6178us RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: Schritt 2, Bild 1 von 1
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: Schritt 3, Bild 1 von 1
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: Schritt 4, Bild 1 von 1
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv7-6178us RAM Replacement: Schritt 5, Bild 2 von 2
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Abschluss
Branden Simas
178 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 564
