Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Having trouble with internet connection? You may have to replace your Wifi chip. This guide will show you the steps you need to take to access and replace your WiFi chip.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.) After that is done, carefully pull off the back piece. It should look similar to the second photo.
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. Now that we have the back piece off, we will need to unscrew the two screws holding the WiFi chip in place.
    • Now that we have the back piece off, we will need to unscrew the two screws holding the WiFi chip in place.
    • Make sure not to lose the screws as they will be needed to replace the WiFi chip.
  3. Remove the WiFi chip from the slot.
    • Remove the WiFi chip from the slot.
Abschluss
Nick Paternostro
419 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 53
