Zum Hauptinhalt wechseln
HP Pavilion dv7t-7000 Hard Drive Replacement
Was du brauchst
  1. HP Pavilion dv7t-7000 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Hard Drive Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 9, Bild 1 von 2 HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Slide the casing off of the hard drive.
  10. HP Pavilion dv7t-7000 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Unplug the hard drive from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 406
