Einleitung
A guide to remove and replace the heat sink in the HP Pavilion dv7t-7000.
Was du brauchst
Hold the release switch all of the way to the left and your other hand to pull the battery out.
Push the retraining springs away from the RAM at the same time to unlock the RAM.
Grab the black tab on the hard drive and pull left and then upwards to remove.
Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
Pry upward to release the keyboard clips.
Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
Pull the ribbon cables out of the ZIF connectors.
Remove the keyboard.
Flip the keyboard back over.
Remove the single Phillips #00 screw holding in the CD drive.
Pull out the CD drive.
Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
Use the flat end of a spudger to disconnect all wires connected to the motherboard.
Lift up the black tab on the ZIF connector with the flat end of a spudger.
Pull the ribbon cable out of the ZIF connector.
Remove the fan from the laptop.
Once you have removed the motherboard, the heat sink is attached.
Flip over the motherboard/heat sink assembly.
Remove the six screws holding the heat sink onto the motherboard.
Unplug the cord supplying power to the fan.
Pull the two pieces apart.
2 weitere Personen haben diese Anleitung absolviert.
