Zum Hauptinhalt wechseln
HP Pavilion dv7t-7000 Keyboard Replacement
Was du brauchst
  1. HP Pavilion dv7t-7000 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Keyboard Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 2 HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 7, Bild 1 von 3 HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 7, Bild 2 von 3 HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 549
