Einleitung
How to replace the speaker on a HP Pavilion dv7t-7000 laptop.
Was du brauchst
Hold the release switch all of the way to the left and your other hand to pull the battery out.
Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
Pry upward to release the keyboard clips.
Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
Pull the ribbon cables out of the ZIF connectors.
Remove the keyboard.
The speaker is located at the back side of the front panel.
Unscrew two screws located at the speaker.
