Einleitung
Often after many uses, a laptops battery will no longer hold its charge. This is the time to replace it. In this laptop, the battery is easy to remove and replace.
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Slide the switch all the way to the left to release the battery. The battery should pop up.
Lift the battery out.
4 weitere Personen haben diese Anleitung absolviert.
