Einleitung
When keyboards become worn or unresponsive, it's typically time to replace them. Replacing a keyboard can be especially difficult, as it's normally secured by many screws. This guide outlines all the steps needed to access the keyboard.
Was du brauchst
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Slide the switch all the way to the left to release the battery. The battery should pop up.
Lift the battery out.
Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
Flip the laptop over and open the lid.
Lift out the plastic panel containing the power button and flip it over.
Locate the ribbon cable attached to the underside of the plastic panel.
Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
Set the plastic panel aside.
Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
Use a spudger to push the black tab forward and slide it away from the white connector.
Gently pull the ribbon cable from the connector housing.
Remove the keyboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
