Zum Hauptinhalt wechseln
HP Pavilion dv9000 RAM Replacement
Was du brauchst
  1. HP Pavilion dv9000 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: Schritt 2, Bild 1 von 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: Schritt 3, Bild 1 von 3 HP Pavilion dv9000 RAM Replacement, RAM: Schritt 3, Bild 2 von 3 HP Pavilion dv9000 RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv9000 RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv9000 RAM Replacement: Schritt 4, Bild 3 von 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 10-32, Maness Winter 2014 Mitglied von Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 3,592
