Einleitung
The motherboard is the meat of your device. Almost everything on the inside such as the fan, mouse pad, and speakers, are all attached. Although the removal and replacement of this component is not difficult, it should be done cautiously.
Was du brauchst
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
In lower left hand corner, pull on black tab to unplug the disc drive.
In upper left hand corner, unplug the large black electrical tape covered laptop plug.
