Zum Hauptinhalt wechseln
HP Pavilion g4-1117dx Motherboard Replacement
Was du brauchst
  1. HP Pavilion g4-1117dx Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide pill shaped tab to the other side of the channel.
    Frag FixBot
    Kommentar hinzufügen
    • Remove battery while keeping the tab to the side.
    Frag FixBot
  2. HP Pavilion g4-1117dx Motherboard Replacement, L-Shaped Back Panel: Schritt 3, Bild 1 von 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
    Frag FixBot
  3. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully pry off the L-shaped panel.
    Frag FixBot
  4. HP Pavilion g4-1117dx Motherboard Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Pull out and unplug the tab on the right hand side.
    Frag FixBot
  5. HP Pavilion g4-1117dx Motherboard Replacement, Larger Back Panel: Schritt 6, Bild 1 von 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
    Frag FixBot
  6. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove 3 screws located where the battery previously was.
    Frag FixBot
  7. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 8, Bild 1 von 2 HP Pavilion g4-1117dx Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
    Frag FixBot
  8. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
    Frag FixBot
  9. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Unplug wires connecting back panel to keyboard.
    Frag FixBot
  10. HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 2 HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • In lower left hand corner, pull on black tab to unplug the disc drive.
    Frag FixBot
  11. HP Pavilion g4-1117dx Motherboard Replacement: Schritt 12, Bild 1 von 2 HP Pavilion g4-1117dx Motherboard Replacement: Schritt 12, Bild 2 von 2
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
    Frag FixBot
Abschluss
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 50
Insgesamt: 1,721
