Einleitung
The speakers are relatively easy to remove. There are no screws. All you need to do is disconnect a wire and pull.
Was du brauchst
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
Fast fertig!
Abschluss
