Zum Hauptinhalt wechseln
Einleitung
If your laptop will not charge or turn on, this is a guide to replace the battery.
Werkzeuge
Keine Werkzeuge angegeben.
  1. Flip the computer so the bottom is facing up with the battery away from you.
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Slide the battery switch to the left until the battery unlatches from the base of the laptop. Slide the battery switch to the left until the battery unlatches from the base of the laptop.
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  4. Lift the battery from its compartment away from the laptop. Lift the battery from its compartment away from the laptop.
    • Lift the battery from its compartment away from the laptop.
Abschluss
Rachel Gallegos
807 Reputation
5 Anleitungen geschrieben
Baylor, Team 10-12, Williams Fall 2015 Mitglied von Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 109
