Zum Hauptinhalt wechseln
HP Pavilion g6-1b79dx Bottom Panel Replacement
Was du brauchst
  1. HP Pavilion g6-1b79dx Bottom Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 2, Bild 1 von 2 HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 3, Bild 1 von 2 HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Bottom Panel Replacement, Bottom Panel: Schritt 4, Bild 1 von 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 5, Bild 1 von 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 6, Bild 1 von 3 HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 6, Bild 2 von 3 HP Pavilion g6-1b79dx Bottom Panel Replacement: Schritt 6, Bild 3 von 3
    • With your hands, lift the panel completely off the base of the laptop.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 10-12, Williams Fall 2015 Mitglied von Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 1,968
