Zum Hauptinhalt wechseln
HP Pavilion g6-1b79dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion g6-1b79dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Hard Drive Replacement, Bottom Panel: Schritt 4, Bild 1 von 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Hard Drive Replacement, CD Drive: Schritt 7, Bild 1 von 2 HP Pavilion g6-1b79dx Hard Drive Replacement, CD Drive: Schritt 7, Bild 2 von 2
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  8. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 8, Bild 1 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 8, Bild 2 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Slide the CD drive out from the exterior of the laptop.
  9. HP Pavilion g6-1b79dx Hard Drive Replacement, Hard Drive: Schritt 9, Bild 1 von 2 HP Pavilion g6-1b79dx Hard Drive Replacement, Hard Drive: Schritt 9, Bild 2 von 2
    • Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
  10. HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 10, Bild 1 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 10, Bild 2 von 3 HP Pavilion g6-1b79dx Hard Drive Replacement: Schritt 10, Bild 3 von 3
    • Pull the triangular blue tab to diconnect and remove the hard drive. You can see the word 'Pull' on the cover.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
patrickhall
730 Reputation
3 Anleitungen geschrieben
Baylor, Team 10-12, Williams Fall 2015 Mitglied von Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
I used my (brand new!) Pro Tech toolkit to work through these instructions. Everything was pretty much as advertised except that my Pavilion g series is apparently older than the displayed model. Specifically, there was no screw to the right of the drive, and the drive is completely encased in a rubber harness that is used to friction seat the drive, and the area where the pull tab would be is covered by a plastic shield that appears to be made of same electrostatic material as antistatic bags. Solution was simply to used standard spudger to lift rear of drive against friction from rubber harness, and then simply unplug the drive. Basically, this was a good doc; it got me going in the right direction.
Raymond L Atkinson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 4,504
