Zum Hauptinhalt wechseln
HP Pavilion g6-2228tx Optical Drive Replacement
Was du brauchst
  1. HP Pavilion g6-2228tx Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion g6-2228tx Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 2 HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: Schritt 6, Bild 1 von 2 HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: Schritt 6, Bild 2 von 2
    • Remove the 2.5mm screw with a Phillips #0 screw drive.
  7. HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 7, Bild 1 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 7, Bild 2 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 7, Bild 3 von 3
    • Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
  8. HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 8, Bild 1 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 8, Bild 2 von 3 HP Pavilion g6-2228tx Optical Drive Replacement: Schritt 8, Bild 3 von 3
    • Grab the optical drive and pull to the left to remove it from the device.
Abschluss
Hai Lin
446 Reputation
4 Anleitungen geschrieben
UC Davis, Team S4-G6, Lore Fall 2018 Mitglied von UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 977
