Zum Hauptinhalt wechseln
HP Pavilion g7-1150us Hard Drive Replacement
Was du brauchst
  1. HP Pavilion g7-1150us Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion g7-1150us Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Hard Drive Replacement, Surface Panel: Schritt 3, Bild 1 von 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g7-1150us Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
    • The hard drive was missing from our device.
  7. HP Pavilion g7-1150us Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the hard drive to the right away from the connector. When fully disconnected you have safely removed the hard drive!
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S6-G3, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G3, Peak Spring 2019
UMASSD-PEAK-S19S6G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 1,076
