Zum Hauptinhalt wechseln
HP Pavilion g7-1365dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion g7-1365dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: Schritt 3, Bild 1 von 2 HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: Schritt 3, Bild 2 von 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Disconnect the drive connector cable from the system board by pulling the plastic tab on top of the connector.
    • Use the opening tool to lift the hard drive out.
    • Remove the hard drive.
Abschluss
Derrick Manu
245 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 386
