Zum Hauptinhalt wechseln
HP Pavilion g7-1365dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion g7-1365dx Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Keyboard Replacement: Schritt 2, Bild 1 von 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Keyboard Replacement, Service Door: Schritt 3, Bild 1 von 2 HP Pavilion g7-1365dx Keyboard Replacement, Service Door: Schritt 3, Bild 2 von 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
  5. HP Pavilion g7-1365dx Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Rest the laptop on its side so the optical drive is pointing up.
    • Insert the hex 2.0 screwdriver into the screw hole that had the 4.7 mm screw, press till the keyboard pops out.
  6. HP Pavilion g7-1365dx Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Turn the laptop right side up, facing you. Use the opening tool to help pull the keyboard towards you.
  7. HP Pavilion g7-1365dx Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Unplug the keyboard ribbon cable and remove the keyboard.
Abschluss
jonathan Rodriguez
109 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 493
