Zum Hauptinhalt wechseln
HP Pavilion g7-1365dx RAM Replacement
Was du brauchst
  1. HP Pavilion g7-1365dx RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RAM Replacement: Schritt 2, Bild 1 von 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RAM Replacement, Service Door: Schritt 3, Bild 1 von 2 HP Pavilion g7-1365dx RAM Replacement, Service Door: Schritt 3, Bild 2 von 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RAM Replacement, RAM: Schritt 4, Bild 1 von 2 HP Pavilion g7-1365dx RAM Replacement, RAM: Schritt 4, Bild 2 von 2
    • Use your fingers to simultaneously pull apart both tabs holding the module.
    • The memory module will pop up once the tabs are pulled so that it can be removed.
  5. HP Pavilion g7-1365dx RAM Replacement: Schritt 5, Bild 1 von 1
    • Directly pull out the memory module as shown.
Abschluss
Rafal Szmyd
181 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 318
