Zum Hauptinhalt wechseln
HP Pavilion g7-1368dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: Schritt 6, Bild 1 von 2 HP Pavilion g7-1368dx Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
Abschluss
Kianna Young
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 264
