Zum Hauptinhalt wechseln
HP Pavilion g7-2023cl Keyboard Replacement
Was du brauchst
  1. HP Pavilion g7-2023cl Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 2, Bild 1 von 3 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 2, Bild 2 von 3 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Keyboard Replacement, Service Door: Schritt 3, Bild 1 von 2 HP Pavilion g7-2023cl Keyboard Replacement, Service Door: Schritt 3, Bild 2 von 2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 3 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 3 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Locate the screw that secures the keyboard.
    • It is near the RAM module and the screw hole is identified by a keyboard symbol with the text underneath it that reads M2.5×6.5.
  6. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
  7. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
    • The release holes are on the base enclosure identified by a keyboard symbol with the word "release" written next to it.
  8. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Turn the device over and open the laptop.
  9. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 9, Bild 1 von 2 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
    • Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
  10. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 10, Bild 1 von 3 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 10, Bild 2 von 3 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Locate the keyboard cable connector.
    • Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
  11. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 11, Bild 1 von 2 HP Pavilion g7-2023cl Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Pull the keyboard ribbon cable out from the connector.
  12. HP Pavilion g7-2023cl Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the keyboard from the device.
Abschluss
Thomas Maloney
1.060 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S8G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 295
