Einleitung
There are a few reasons to replace the keyboard. The keyboard is missing keys, a few keys do not work anymore, or the entire keyboard is broken. Whatever the reason, this guide will show you how to replace the keyboard.
Was du brauchst
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Use your thumb to pry up the edge of the battery and lift it out of the device.
Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
Locate the keyboard cable connector.
Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
