Zum Hauptinhalt wechseln
HP Pavilion g7-2023cl Optical Drive Replacement
Was du brauchst
  1. HP Pavilion g7-2023cl Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Optical Drive Replacement, Service Door: Schritt 3, Bild 1 von 2 HP Pavilion g7-2023cl Optical Drive Replacement, Service Door: Schritt 3, Bild 2 von 2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Optical Drive Replacement, Optical Drive: Schritt 5, Bild 1 von 2 HP Pavilion g7-2023cl Optical Drive Replacement, Optical Drive: Schritt 5, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
  6. HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Insert the flat end of a spudger into the optical drive release access hole.
  7. HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 7, Bild 1 von 3 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 7, Bild 2 von 3 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 7, Bild 3 von 3
    • Orient the device so that you can remove the optical drive.
    • If you are missing the bezel (face of the optical drive) or have the bezel these same steps work to remove the optical drive.
    • Using a spudger, slide out the optical drive enough so that you can grab it with your hand.
  8. HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 8, Bild 1 von 2 HP Pavilion g7-2023cl Optical Drive Replacement: Schritt 8, Bild 2 von 2
    • Remove the optical drive by pulling it out of the device.
    • When replacing the optical drive, slide it completely back into the slot so that it fits flush.
Abschluss
Thomas Maloney
1.060 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S8G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 161
