Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
There are a few reasons to remove/replace the service door. The service door is cracked, the screw that is attached to the service door is stripped, or you simply need to access the internal parts of the device. Whatever the reason, this guide will show you how to remove and replace the service door.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. Use your thumb to pry up the edge of the battery and lift it out of the device. When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure. When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Using a Phillips #0 screwdriver, loosen the service door screw. This is a captive screw that will remain attached to the service door.
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  5. Lift the service door up and away from the device. Lift the service door up and away from the device.
    • Lift the service door up and away from the device.
Abschluss
Thomas Maloney
1.060 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S8G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 93
