Zum Hauptinhalt wechseln
HP Pavilion g7-2275dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 1, Bild 1 von 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the plastic cover from the hard drive.
Abschluss
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
5 weitere Personen haben diese Anleitung absolviert.
Erik Miller
2.141 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 11-51, Amido Spring 2014 Mitglied von Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 5,183
