Zum Hauptinhalt wechseln
HP Pavilion g7-2275dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion g7-2275dx Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    Frag FixBot
  2. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 2, Bild 1 von 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
    Frag FixBot
  3. HP Pavilion g7-2275dx Keyboard Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: Schritt 3, Bild 1 von 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
    Frag FixBot
  4. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Pavilion g7-2275dx Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Slide the back panel down and pull it up.
    Frag FixBot
  5. HP Pavilion g7-2275dx Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
    Frag FixBot
  6. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Flip the laptop over and open the screen.
    Frag FixBot
  7. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Pavilion g7-2275dx Keyboard Replacement: Schritt 7, Bild 2 von 2
    • A ribbon cable is attached to the back of the keyboard. Avoid lifting or moving the keyboard more than a couple inches before you disconnect the ribbon cable or you may damage it.
    • Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
    • The keyboard may make some cracking noises as you pry it from the casing. This is expected.
    • Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
    Frag FixBot
  8. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Gently turn keyboard over, towards you, to reveal the silver cable ribbon.
    Frag FixBot
  9. HP Pavilion g7-2275dx Keyboard Replacement: Schritt 9, Bild 1 von 3 HP Pavilion g7-2275dx Keyboard Replacement: Schritt 9, Bild 2 von 3 HP Pavilion g7-2275dx Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
    Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 11-51, Amido Spring 2014 Mitglied von Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Mitglieder
21 Anleitungen geschrieben
3 Kommentare zur Anleitung
No hay información
Yofre Cuenca Tene - Antwort Teilen
Good guide. It helped me going quicker at getting to the keyboard. Thank you!
antoniotavares - Antwort Teilen
The keyboard for this computer is HP part number 640208-001 and it is not available anymore in HP. It is available in Amazon, however.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 70
Insgesamt: 11,829
