Einleitung
Is your wifi running incredibly slow or not connecting at all? If your laptop is the only device having problems, then replacing your wireless card may help.
Was du brauchst
The battery is held in by a latch in the front and tabs in the back.
Slide the lock switch left, towards the center of the computer.
Lift up the battery, rotating it up and away from you, then pull it out.
Unscrew one Phillips #1 screw from the back panel.
Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
Pull the black and white wires up and off of the wireless card.
Remove the wireless card.
2 weitere Personen haben diese Anleitung absolviert.
