Zum Hauptinhalt wechseln
HP Pavilion x2 10-n113dx Battery Replacement
Was du brauchst
  1. HP Pavilion x2 10-n113dx Battery Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Battery Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 3, Bild 3 von 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Battery Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 4, Bild 3 von 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x2 10-n113dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S13-G4, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 40
Insgesamt: 4,936
