Zum Hauptinhalt wechseln
HP Pavilion x2 10-n113dx Screen Replacement
Was du brauchst
  1. HP Pavilion x2 10-n113dx Screen Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Screen Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 2, Bild 2 von 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Screen Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 3, Bild 3 von 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Screen Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 4, Bild 3 von 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Screen Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Screen Replacement, Screen: Schritt 6, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement, Screen: Schritt 6, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement, Screen: Schritt 6, Bild 3 von 3
    • Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
    • 3.32 mm head, 3.99 mm length.
    • 2.82 head 3.5 mm length.
    • 4.15 mm head, 2.35 mm length.
  7. HP Pavilion x2 10-n113dx Screen Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x2 10-n113dx Screen Replacement: Schritt 7, Bild 3 von 3
    • Very carefully lift the circuit board in order to keep everything attached. Be careful with any cables that may still be connected.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S13-G4, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
where can i get the replacement screen for this model
Umer Muhammad Anwar - Antwort
where can i get the replacement screen for this model?
Olumuyiwa Oyenuche - Antwort
This guide is bad. He takes the same screws out twice. There is more than 21 screws. Do not follow this guide you will end up breaking something.
matthewcomley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 6,011
