Zum Hauptinhalt wechseln
HP Pavilion x360 11-p110nr Hard Drive Replacement
Was du brauchst
  1. HP Pavilion x360 11-p110nr  Hard Drive  Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  2. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: Schritt 2, Bild 1 von 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
    • Remove the nine screws from the back panel using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: Schritt 3, Bild 1 von 1
    • Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
    • Pull the hard drive up and out to remove it from the compartment.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 2,244
