Einleitung
If your computer has a jammed key on the keyboard, within this guide you will find quick and easy directions on how to resolve the issue.
Was du brauchst
Use a screwdriver or other flat instrument to get under the key, and pull up slightly on one of the edges.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Clear out any obstructions or crumbs that are jamming the key or the hinges underneath.
You may use a Q-tip, toothpick, or tweezers.
Use the flat screw to put the key back into place.
Gently press the key down. It should snap back into place
