Zum Hauptinhalt wechseln
HP Pavilion x360 11-p110nr Speakers Replacement
Was du brauchst
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: Schritt 1, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: Schritt 1, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: Schritt 1, Bild 3 von 3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 2, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 2, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 2, Bild 3 von 3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 3, Bild 3 von 3
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 6, Bild 1 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 6, Bild 2 von 3 HP Pavilion x360 11-p110nr Speakers Replacement: Schritt 6, Bild 3 von 3
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
Abschluss
Aeorrell
433 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-2, Harley Spring 2023 Mitglied von IUPUI, Team 1-2, Harley Spring 2023
IUPUI-HARLEY-S23S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 72
