Einleitung
This guide helps you to replace your speakers on your HP laptop using only a screwdriver, tweezers, and the replacement part. The entire process is fairly quick and easy, and with a bit of care, it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around the electricity and always unplug the battery before you attempt to replace the port.
Was du brauchst
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Carefully take the bottom cover off.
Before fully removing the top cover, locate the cable that connects the audio controls.
Once located, lift the small black flap and carefully pull the cable out.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the cable for the speakers and unplug, as shown.
Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
