Zum Hauptinhalt wechseln
HP Pavilion x360 11-p110nr Touchpad Replacement
Was du brauchst
  1. HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: Schritt 1, Bild 1 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: Schritt 1, Bild 2 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: Schritt 1, Bild 3 von 3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Once the screws are removed, carefully take the bottom plate off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 2, Bild 1 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 2, Bild 2 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the five 6.7 mm screws that secure the battery.
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the hard drive.
    • Locate the cable for the battery and the cable for the speakers and unplug those as well.
  4. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Once all screws are removed, carefully remove the battery and hard drive as one unit.
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  5. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Once the battery and hard drive are removed, you should be able to see the touchpad.
  6. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 6, Bild 1 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 6, Bild 2 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Find the cable for the touchpad and unplug it.
    • Remove and install carefully as to not damage the cable.
  7. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the touchpad bracket.
    • Slowly lift up the bracket and remove it.
  8. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 8, Bild 1 von 2 HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 8, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 2.35 mm screws that secure the touchpad.
    • Remove the cover holding the touchpad in place.
  9. HP Pavilion x360 11-p110nr Touchpad Replacement: Schritt 9, Bild 1 von 1
    • You can now remove and replace the trackpad.
    • Be careful not to scratch the screen during the replacement of the trackpad as the screen will be located directly underneath the trackpad.
Abschluss
Aeorrell
433 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-2, Harley Spring 2023 Mitglied von IUPUI, Team 1-2, Harley Spring 2023
IUPUI-HARLEY-S23S1G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 75
