Einleitung
If the keyboard on your HP Pavilion x360 11m-ad013dx has stopped working or is in need of replacement, use this guide to replace the keyboard. For more information about malfunctioning keyboards, see our troubleshooting page: HP Pavilion x360 11m-ad013dx Troubleshooting. The keyboard panel contains the keys themselves, as well as the touchpad. The panel also provides access to the internal section of the laptop, containing the battery, hard drive, motherboard, etc.
Was du brauchst
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Eine weitere Person hat diese Anleitung absolviert.
