Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0003dx Fan Replacement
Was du brauchst
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 2, Bild 2 von 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 4, Bild 1 von 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the heat sink assembly from the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 535
