Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0003dx Hinges Replacement
Was du brauchst
  1. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Screen: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 3, Bild 1 von 1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 4, Bild 2 von 2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 5, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 5, Bild 2 von 2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 6, Bild 1 von 1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 7, Bild 3 von 3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 8, Bild 1 von 1
    • After the cable has been disconnected, the screen can be removed.
  9. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Hinges: Schritt 9, Bild 1 von 1
    • Remove the three Phillip Head screws (5 mm)that hold in the bracket on each side.
  10. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 10, Bild 1 von 1
    • Slide the frame down past the brackets on each side.
  11. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 11, Bild 1 von 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 11, Bild 2 von 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 11, Bild 3 von 3
    • Lay the laptop flat on your working surface.
    • Flip it over to get access to the back panel.
    • Remove the back panel screws and take off the back cover.
  12. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 12, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 12, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screws from the hinges on each side inside the laptop.
  13. HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 13, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: Schritt 13, Bild 2 von 2
    • Remove the hinges from both sides of the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Elijah Jope
379 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 52
Insgesamt: 2,628
