Einleitung
This guide helps you with removal and replacing the Touchpad for HP Pavilion x360 14m-cd0003dx laptop. If your computer's touchpad does not respond to user input , it may need to be replaced.
For further information to determine if the Touchpad needs to be replaced, please refer to this troubleshooting guide.
Was du brauchst
Turn off the computer.
Disconnect the power cord and any external devices connected to the computer.
Flip the device so that the back plate of the laptop is up.
Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
Pry off the back cover with the spudger tool.
Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
Remove the metal plate that secures the touch pad.
Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
Remove touch pad.
