Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Was du brauchst
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: Schritt 4, Bild 1 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: Schritt 4, Bild 2 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: Schritt 4, Bild 3 von 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 6, Bild 1 von 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Abschluss
Elijah Jope
379 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 417
