Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement
Was du brauchst
  1. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 2, Bild 1 von 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 3, Bild 2 von 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 5, Bild 3 von 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: Schritt 6, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: Schritt 6, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 7, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Heat Sink and Fan: Schritt 8, Bild 1 von 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 9, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 10, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 10, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 10, Bild 3 von 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 11, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: Schritt 11, Bild 2 von 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 538
