Zum Hauptinhalt wechseln
HP Pavilion x360 15t-br000 RAM Replacement
Was du brauchst
  1. HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: Schritt 1, Bild 1 von 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: Schritt 1, Bild 2 von 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: Schritt 1, Bild 3 von 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 RAM Replacement: Schritt 2, Bild 1 von 3 HP Pavilion x360 15t-br000 RAM Replacement: Schritt 2, Bild 2 von 3 HP Pavilion x360 15t-br000 RAM Replacement: Schritt 2, Bild 3 von 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 RAM Replacement, Battery: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 RAM Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 15t-br000 RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: Schritt 5, Bild 1 von 2 HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Disconnect the five cable connections to the motherboard.
  6. HP Pavilion x360 15t-br000 RAM Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
  7. HP Pavilion x360 15t-br000 RAM Replacement: Schritt 7, Bild 1 von 2 HP Pavilion x360 15t-br000 RAM Replacement: Schritt 7, Bild 2 von 2
    • Lift the motherboard carefully then remove the motherboard.
  8. HP Pavilion x360 15t-br000 RAM Replacement, RAM: Schritt 8, Bild 1 von 1
    • Turn over motherboard and remove the RAM carefully from motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 276
