Einleitung
If your HP Pavilion x360 Convertible 14-dw1025nr is not displaying graphics or is not distributing audio, the laptop's motherboard may be damaged. Use this guide to replace it.
The motherboard is the backbone of a laptop and controls multiple parts within the laptop.
Replacing the motherboard of a laptop is not a common procedure. Most replacements within a laptop are for components that are attached to the motherboard. The motherboard should only need to be replaced in extreme situations where a separate component attached to the motherboard cannot be replaced.
Replacing the motherboard is not a difficult task, but it does require a lot of steps and there will be many small pieces to keep track of. There are various screws and a few loose plastic parts that will come out when exposing the motherboard. This replacement will not require any difficult tasks such as soldering or rewiring.
Was du brauchst
Turn off the device and set it upside down. Orient the hinges away from you.
Wedge the opening pick under the grip. Lift the end of the grip.
Pull the grip off all the way. Repeat for the second grip.
Use a Phillips #0 screwdriver to remove the 3 mm screw from the center bottom.
Use a Phillips #1 screwdriver to remove the 6 mm screw from all four corners of the bottom cover.
Use the opening pick to separate the back panel from the device.
Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
Lift the panel off.
Use a Phillips #1 screwdriver to remove all four of the 4 mm screws that secure each corner of the battery.
Use the opening tool near the connector to gently apply pressure and lift the battery away from the device.
Once loose, lift the battery from the connector side to separate it from the device.
Disconnect connectors 1 and 2 of the wireless card using the spudger.
Remove the sticker covering the touch sensor connector using the angled tweezers.
Firmly pinch the plastic loop and pull straight up to disconnect the touch sensor.
Use the spudger to disconnect the cable to the left of the touch sensor connector.
Use the spudger to lift the black flap of the keyboard connector.
Use the angled tweezers to carefully grip and pull out the ribbon cable.
Use the angled tweezers to remove the clear sticker covering the trackpad connector.
Use the spudger to lift the white flap of the connector.
Use the angled tweezers to pull out the ribbon cable.
Use PH1 to remove the 3 4mm screws holding the fan.
Lift the fan up and away from the heat pipe.
Slightly lift the heat pipe with one hand.
Using your other hand, lift the small part of the motherboard up and away from the laptop frame.
Lift the right side of the large portion of the motherboard up and away from the frame of the laptop.
