Zum Hauptinhalt wechseln
HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement
Was du brauchst
  1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): Schritt 1, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): Schritt 1, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): Schritt 1, Bild 3 von 3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 2, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 2, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 2, Bild 3 von 3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 3, Bild 3 von 3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 4, Bild 2 von 2
    • Pinch and lift the small WLAN plate.
  5. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 5, Bild 1 von 1
    • Use PH1 to remove the 2.5mm holding screw.
  6. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 6, Bild 1 von 2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: Schritt 6, Bild 2 von 2
    • Pull the SSD out and up, away from the connector.
Abschluss
Amber Norton
661 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 46
Insgesamt: 667
