Einleitung
If keys are malfunctioning (sticking or not registering), this guide will explain how to replace your keyboard. To replace your keyboard, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Was du brauchst
Power off your device and disconnect all external devices connected to the laptop.
Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
5 Phillips 2.4 x 5.7 mm screws
7 Phillips 2.0 x 5.0 mm screws
Flip the laptop back over and open it; the keyboard should be facing upwards.
Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
Eine weitere Person hat diese Anleitung absolviert.
