Zum Hauptinhalt wechseln
HP Pavilion x360 m3-u001dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion x360 m3-u001dx Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 5, Bild 2 von 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    Kaufen
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the keyboard away from the base of the laptop.
Abschluss
Follow these instructions in reverse order to reassemble your device.
2 weitere Personen haben diese Anleitung absolviert.
Subhleen
1.268 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team 1-6, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 Mitglieder
8 Anleitungen geschrieben
4 Kommentare
Where's the replacement?
I have just the keyboard without the panel. How can I replace that?
Melwyn Williams - Antwort
you have to pry off like 50 stupid dinky little rubber clips from the underside of the palmrest that hold the keyboard onto the palmrest. then insert your new keyboard and solder it on to the bottom side of the palmrest. I used the little rubber clips as solder when I replaced a non-backlit keyboard for a backlit one on a pavilion x360. it’s tedious, and you do need a soldering rod.
Stallion K -
I’d like to clean the under part of my keyboard keys on Hp Paviliion 360, how do I go about that?
Hawkins Lee - Antwort
You have to read my comment right above and detach the keyboard from the palmrest on the underside by prying off the dinky little clips holding the keyboard to the palmrest . Then you'd be able to clean the keyboard as it would be free from the palmrest. Then you'd have to reassemble it with a soldering rod. Good luck. This is why HP sells the keyboard and palmrest as one piece for this laptop. It's a difficult job to separate the two and as if not more difficult reassembling it.
Stallion K -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 6,152
